Bore ideas
Old Nov 27, 2015 | 07:18 AM
Brads91crxsi's Avatar
Default Bore ideas
Son is have a b18c1 completely broken down everything worked be for it pulled it all apart but it had been sitting for 7 years andown wanted to replace all the seals and gaskets and just look over the internals. Now that I have it all broke down I have port and polished the head and just fine tune little stuff. My question is should (while I have the engine all apart) I bore out the engine, I want to turbo the car but I also just want to get the CRXsi back on the street dose anybody have any ideas or thoughts on boring the engine if I'm going to turbo it, or should I just put it all back together?
Default Re: Bore ideas
So I not son is
Old Nov 28, 2015 | 01:18 AM
PyroProblem's Avatar
I would only bore it out if you have damage and it's absolutely needed OR your looking for every bit of HP and increasing displacement is the last thing left. My opinion.
Old Nov 28, 2015 | 06:44 AM
Hey Pyro thanks for the input. I had run into a old friend who is huge into racing and I showed him pics and he same the same thing don't bore it cause I was super clean and no real need to for the direction I want to go.
Old Nov 28, 2015 | 02:22 PM
spAdam's Avatar
Loved
Community Favorite
Pics can't tell you very well if it needs to be bored or not. The cylinders should be measured for taper/out of round/etc. and then the decision can be made. Have the block measured up, don't order pistons until you know either way.
Old Nov 29, 2015 | 08:46 AM
Agreed 100%.
Take it to a machine shop and have everything measured. They will be able to tell you what you NEED to do. Even though it ran fine 7 years ago, the bores may not be perfectly round. You will want the bores perfect, especially with a performance type build.
Good luck!
dansaleen_04
Jun 6, 2012 02:10 PM
Slomies
Nov 7, 2005 11:51 AM
iguano
Nov 21, 2004 04:22 PM
booscivic
Jun 27, 2004 05:10 PM
quik sol
Oct 20, 2003 10:22 PM
