Bisimoto 3.6 cam install
I know you have to do machine work but i dont know where. There is a post on here but the pic are no longer present can someone please help me?
Head setup is
Bisimoto3.6 cam
Bisimoto springs
Bisimoto retainers
Bisimoto keepers
Bisimoto valves
Head setup is
Bisimoto3.6 cam
Bisimoto springs
Bisimoto retainers
Bisimoto keepers
Bisimoto valves
Re: Bisimoto 3.6 cam install
Can you be any more vague?
What specifically is it that you would like to know?
Where exactly i need to grind to get the camshaft to move freely and fit properly
From what small info I found this cam is extremely big.
But, I would say if anything needs to get machined it would be the cam caps. And also found something about making the sinking the valve seats.
https://honda-tech.com/forced-induct...tions-2954570/
LOL good luck, your going to need it.
Ū
ŪYes i have just looked with my eyes but i see no contact any where. It get close to the sides but not rubbing. I just wish i could get pictures. Thanks guys
I don't have pics, but with the cam lubed and test fitted, slowly rotate it and you will see where the lobes don't have clearance or not enough. Usually near the edge of where the valve cover comes in contact with the head or spark plug tube area. Make sure you check all clearances before buttoning it up. v2v, p2v, rockers, etc...
