b18c5 pistons in b18b block
Old Oct 31, 2015 | 11:46 AM
1/4mi4banger's Avatar
Icon5 b18c5 pistons in b18b block
So I inherited a box of rebuild stuffs with my donor integra, I figured I might as well try and use everything I can before I start spending. The question is, will b18c5 pistons work in a b18b block? if so what needs to be modified? and will the engine be able to handle the increased compression?
I'm not new to engines. I can rebuild a hell of a small block v8. but I am fresh to Hondas, any input would be greatly appreciated!
Old Oct 31, 2015 | 01:48 PM
PyroProblem's Avatar
Default Re: b18c5 pistons in b18b block
Bore size is the same for both engines. So as long as your PTW clearances are ok, they should work.
Old Oct 31, 2015 | 02:35 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Also, the compression height can throw a monkey wrench into the works. Don't want the piston coming out of the block in most cases.
Will have to look at the specs of the two B series motors. If the deck height and the rod length is the same on both motors with the same stroke, then you know the compression height will be the same or acceptable.
JDMx2103
Jul 25, 2009 09:09 AM
93coupe1330
Jan 11, 2009 09:13 AM
ITRfaithful
Feb 14, 2003 08:51 AM
Mase
Oct 22, 2002 09:10 AM
