Rebuilt block sitting
Old Mar 2, 2016 | 11:23 AM
_Turbogsr's Avatar
Default Rebuilt block sitting
Hey guys, i got a built ls block that i built about a year ago and its been sitting ever since. I was just wondering if its bad to let it sit so long because i'm about to finish it and put it into my civic.
Old Mar 2, 2016 | 12:10 PM
motoxxxman's Avatar
Default Re: Rebuilt block sitting
as long as it has not started to rust anywhere, it's fine for it to sit. its always good practice to coat all steel parts in oil and wrap it in plastic if you know it's going to sit.
if it has started to rust, wet a rag with automatic transmission fluid and scrub the cylinders with it, should take most or all of it off. just clean it well after. if the surfaces are still rough from rust after doing this, it may need to be re-honed a little, but that may or may not open up the piston to wall clearance a little.
Old Mar 2, 2016 | 03:11 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
I made this a few years back. It may or may not be of use to you since it's already been sitting. Hope it helps though...
https://honda-tech.com/honda-crx-ef-...orage-3012754/
PS - You can do this to an engine that isn't running, it's just not AS effective.
Old Mar 2, 2016 | 06:18 PM
_Turbogsr's Avatar
Alright thanks guys, Ive had it wrapped in plastic ever since and i turn it over once in a while and no rust so i guess i should be good.
97grnrs
Aug 8, 2008 03:37 PM
1991hondahead
11
Sep 21, 2004 05:00 PM
int3gra
Mar 2, 2004 10:02 PM
boosted_dc2
Jan 27, 2004 09:36 PM
TOFU.man
Nov 4, 2003 06:27 AM
