NC engine builders
Old May 22, 2016 | 06:08 AM
346ci's Avatar
Default NC engine builders
I've searched some here and have found some posts on the topic but all were a few years old.
My '00 Civic with the 1.6L SOHC Vtec and 200K on the clock is burning a qt of oil every 800 miles. It still runs great and gets 34mpg.
I want to start researching Honda engine builders in my area. The car is my daily driver, 100% stock and has been very reliable. I'm looking to go back with all OEM parts to get another 200K out of her.
So far I've found;
KMOD in Asheboro, about an hour from me. Engine rebuilding looks to start at $1950.
National Speed in Wilmington, about 2 hours from me. Looks like I will have to contact them for prices.
Thanks
Old May 22, 2016 | 08:45 AM
1991_crxsi's Avatar
Default Re: NC engine builders
J.Mills tuning just outside of Raleigh. Great guy, great work, great prices. Give him a call and let him do the work. You will be pleased. https://www.facebook.com/JMillsTuning/
Another option is to sell the engine and swap it for a low mileage JDM equivalent. He can do the swap for you.
Old May 22, 2016 | 10:50 AM
Casey's Avatar
kmod is a joke
national speed in wilmington will do great work, RLZ in concord does great work
Old May 22, 2016 | 11:44 AM
PyroProblem's Avatar
If oil consumption is the primary reason for the rebuild, id start with new valve stem seals first to see if it helps.
@ 200k miles and 16 years old, they're probably leaking.
If you think about it they are rubber and can leak just like any other gasket on the engine.
But valve stem seals are under vacuum pretty much all of the time the engine is running so the engine is always trying to suck oil past the valve stem seals.
I know I didn't answer your question directly, just want to make sure you don't accidentally fix what nots broken and save you a few bucks.
Old May 24, 2016 | 02:16 AM
346ci's Avatar
I will contact J Mills and Nat Speed to see what they have to say.
Valve seals are possible but there isn't any smoke, might pull the valve cover just to see what they feel like. I did try soaking the cylinders overnight for the oil rings but didn't help.
Thanks everyone.
Old May 24, 2016 | 01:14 PM
92TALTSI's Avatar
I personally use rlz but they take to f@#@ long !
custom kings auto shop Will take great care of you and have great pricing ..... NC local
Yuta
Oct 19, 2015 04:27 AM
Aar0n
Nov 29, 2014 02:02 AM
MayorMcCheese
Dec 23, 2011 07:34 AM
Skinman
Oct 7, 2008 12:23 PM
bey
Sep 24, 2003 02:28 PM
