engine cleaning brushes
Old Jun 1, 2016 | 05:31 AM
1988dxsedan's Avatar
Default engine cleaning brushes
can anyone recommend a good set of brushes for cleaning b series oil and coolant passages? im picking up my block this week from the machine shop and I will be cleaning it through and through. I have searched for specific sizes I may need and turned up nothing. I know goodson makes a kit for like 40 bucks, with 10 brushes. moroso also has a similar kit. not sure if the sizes I need are in those kits. also as far as brush material: is nylon a good option? seems like most of the kits are nylon, but wasn't sure what was actually best to use. thanks guys.
matt
Old Jun 1, 2016 | 08:03 PM
PyroProblem's Avatar
Default Re: engine cleaning brushes
I just use a little cheapy kit from harbor freight. Its has 3 types of brushes (brass, nylon, and stainless steel I believe). The nylon works fine. I suppose brass or stainless would also work, but its not really needed. The passages shouldn't need that aggressive of a cleaning. my 2 cents.
1990_crx-si
25
Jul 30, 2009 07:31 AM
broketuner-Sol_Si
Sep 14, 2006 08:12 AM
egeeb16
Feb 22, 2006 11:24 AM
egerdahl
Jan 28, 2006 02:00 AM
