D16z6 monroso oil pan
So my oil pan been leaking and I came to the conclusion it's been bent all along! Fml so I came across the moroso oil pan. Seems like a pretty penny for an oil pan unless It actually makes a difference. Doesn't all oil pan have baffles to keep a constant flow? Anyways I'll like to hear what you guys think btw this is for a built turbo d16 If that matters.
Re: D16z6 monroso oil pan
The Canton pan is at the top of the heap . . .
The moroso has more baffling and a couple of doors over the OEM pans which prevent the oil from leaving the pickup under hard braking
