Is this head cracked?
Old Jun 11, 2016 | 06:55 AM
BoostAndBoobs's Avatar
Default Is this head cracked?
Hey guys, just pulled the valve cover and everything off my boosted ls, want to know if this is a cracked head.
Old Jun 11, 2016 | 03:04 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Is this head cracked?
Coolant in the oil and a massive crack that can be seen with the naked eye and you need to ask if it's cracked?
Old Jun 11, 2016 | 08:29 PM
king06's Avatar
Chocolate, so yes.
Old Jun 11, 2016 | 10:10 PM
PyroProblem's Avatar
Looks cracked to me. Pressure test the cooling system and see if you see it leaking.
Old Jun 12, 2016 | 12:34 PM
I just asked guys because I'm no expert. I tore it apart because I wanted to see if the headgasket was blown. But it also looked like someone surfaced the bottom of this head with a brick. So new head, I guess.
Old Jun 12, 2016 | 03:54 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
No worries, just when you can actually see the crack and you have chocolate milkshake oil in the head, you know without any doubt it or the block or both are cracked.
The suggestion of pressuring the coolant system is a good one. You will likely see the coolant coming out of that crack to verify beyond any doubt.
The cracks that are unsure of are the microscopic ones you can't see without magneflux dying the head heads or block. Being an aluminum head and block, it's a special dye used to isolate cracks.
In your case, don't need to go through that process as you can see it with the naked eye. And it's so large, pressuring the coolant should easily confirm.
Better luck with your next head.
Old Jun 12, 2016 | 07:09 PM
Where you located OP? I have a couple extra LS heads laying around taking up space.
Old Jun 12, 2016 | 07:17 PM
Actually... That passage that is cracked is for oil, not coolant. I just looked at one and removed the rocker arm base (?) with a 17mm. It does in fact appear to be cracked, but your coolant is coming from somewhere else...
Old Jun 12, 2016 | 10:44 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
He's cracked on the intake and the exhaust channel, is both sides for oil?
Old Jun 13, 2016 | 12:09 AM
That's what it looks like to me. Those oil galleys appear to feed the ball part of the rocker arm. After realizing that, there's no reason for coolant to be that high in the head. Definitely an oil passage.
Old Jun 13, 2016 | 04:48 AM
Hey guys. The coolant in the oil is from this: i dont think the crack caused this.
[IMG]https://cimg3.ibsrv.net/gimg/honda-tech.com-vbulletin/2000x1504/80-20160612_163855_c7a5144e8ff7f825c094032e08c4c0e1e8 03f2c9.jpg[/IMG
It also looked like whoever had this car before me surfaced this head with a god damn brick. All 4 cylinders were blown and a couple coolant passages were blown. The scratches were so deep you could take your nails across them and hear it. And im also located in Maryland.
nelson9994
10
Nov 2, 2011 07:57 PM
Usdmowns
Mar 9, 2008 10:36 PM
whoneedzvtec
Mar 16, 2007 07:43 PM
jdmkid_82
Jan 8, 2007 11:57 PM
89 pos
Nov 4, 2005 01:55 PM
