What coolant hose is this? - Honda-Tech - Honda Forum Discussion
Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Old 04-16-2017, 12:30 PM
Default What coolant hose is this?
Found my coolant leak.
What ID size hose is this on the right?
This is the actual hose on my car
kaivorth is offline
Old 04-16-2017, 05:40 PM
Sanji
toyomatt84's Avatar
Default Re: What coolant hose is this?
That's not a coolant line, that's an A/C line.
Judging by the location: 80315-S5A-013 is the part number of what you're looking for.
toyomatt84 is offline
Old 04-16-2017, 06:43 PM
Whoa, so it's not going to be as easy as I thought..
Any guides on changing this AC line? Haven't done one before, and I'm not seeing much info on it.
kaivorth is offline
Old 04-16-2017, 06:56 PM
Sanji
toyomatt84's Avatar
Well, only one bolt holds the fitting on the A/C pump, and only one bolt holds it to the Condenser. So, it's rather easy to remove/install, as long as you can get to the bolts.
Old 04-16-2017, 07:02 PM
In theory easy. I'm not aware how the AC system works, but the AC uses coolant, as well as a refrigerant? This hose is leaking coolant I'm thinking, and I'm filling my overflow res every week
kaivorth is offline
Old 04-18-2017, 11:14 AM
bandit67's Avatar
I am kinda like toy, if that hose is leaking coolant and refrigerant, not sure anybody here will be of much help. Keep us informed......
bandit67 is offline
Old 04-18-2017, 08:46 PM
Sanji
toyomatt84's Avatar
That hose cannot leak coolant. Its an entirely isolated system that is pressurized far greater (roughly 200psi) than your engine's coolant system (roughly 15psi). There's really no way for the two systems to ever make contact.
As for your coolant loss, you may have a blown headgasket. Are you filling your overflow bottle to the top? Because it really shouldn't have too much coolant in it (hence the name "overflow").
Old 05-07-2017, 11:33 AM
Long story short, I left the AC line the way it is. I don't seem to have a coolant leak I guess. I changed my coolant awhile ago, and I think the system is still just burping itself out or something.
That or the spring temps sealed up whatever leak I had.
I filled the overflow res to the min mark, and I'm just driving it monitoring levels.
kaivorth is offline
Old 05-07-2017, 09:41 PM
Yeah, the one in the picture is an AC hose. It contains refrigerant. Specifically R134a. It does not contain coolant. I'd fix that soon because then you'll have no AC if it bursts.
prodjay10 is offline
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
Question Title:
Description:
