P1457
P1457
I have a 2001 Civic EX coupe and have a P1457 error code. this happened a few weeks ago and I replaced the evap two way bypass valve. Now the error has returned. what else could it be?
Re: P1457
Before you replaced the EVAP two-way valve, did it not hold vacuum? If held vacuum - then it was good. This part is the most common part to fail when P1457. Did you replace the canister at the same time?
Time to troubleshoot the rest of the EVAP system for leaks, electrical continuity and failed parts.
