Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Front Parking lights / signal not turning on
Old 05-13-2017, 04:59 PM
rdemel's Avatar
Default Front Parking lights / signal not turning on
Hello,
So I have a 2005 Acura EL.. basically a civic. When I turn the switch one position to parking lights, the the front lights do not turn on, rear lights are on and so is dash light. High beam and low beam work fine. When I turn on the left or right signal lights, only the signal lights next to the fog lights work for the front (rear signal lights work), but the front side signal lights next to the head lights do not work.
Are front parking lights the same as the signal lights?
Car had been in an accident years ago so could be a wiring issue somewhere too but everything was working fine until recently. Any ideas where I should start?
Thanks in advance.
Old 05-15-2017, 05:26 AM
NDNV's Avatar
Default Re: Front Parking lights / signal not turning on
I know one thing for sure is that the parking lights next to the headlights DO NOT operate with the signal lights. So those lights are operating normally as per your description.
See the attached taken from your 2005 EL Owner's Manual on the headlight switch functions.
Could be that the switch is operating as it should?
Do you have DRL?
File Type: pdf
janz3n
05-22-2012 04:40 PM
beginmyhonda
08-04-2011 08:01 AM
HondaKPX
07-25-2005 10:44 PM
specbb6
05-27-2005 01:03 PM
Quick Reply: Front Parking lights / signal not turning on
