Apexi VAFC wiring
Re: Apexi VAFC wiring
You're definitely right it is, But I've been trying to look for a diy for the install. None of the threads I found arent even walkthroughs. I need an walkthrough so I know what to do before I hack into my ECU wires.
Yeah I've realized that. Apexi VAFC is pretty old. I can see why but at least someone had to do a write up. I mean I can't be the only one present day who wants to do a headswap and run a VTEC controller.
Moderator
BTW, did you receive your PDF?
I don't see why you'd expect that, honestly in this day & age. Just because someone performed that install doesn't mean they were altruistic enough to create an entire write up. People just aren't that nice anymore, and would rather leech off of other's efforts rather than acknowledge their efforts for their work-product . Not like even 10 years ago, when it was at least fun to help out.
Sanji
We used to have an active thread DIY for the head swap, but the pictures are down.
https://honda-tech.com/forums/honda-...-vtec-1628016/
Moderator
Yeah I did receive it thanks it actually helped me wire it up. I have 2 pressure signal wires left to wire and a throttle signal. I'm kinda confused on how to run the 2 pressure signal wires. Anyway I can just hook them up to the same wire without cutting? And I'm guessing those run to the map sensor? And then the throttle signal wire runs to the TPS? So many questions lol.
stasikjan
10-28-2008 10:37 AM
hondaon18's
05-22-2007 01:31 PM
alexdofromsantacruz
05-08-2006 02:45 PM
