back fire during shift is this normal
Old Jan 5, 2009 | 05:13 PM
ashb82's Avatar
Default back fire during shift is this normal
i got my car tuned. It runs flawless. I drive it around on the street at 8psi. My afr is 11.5 to 12.0. when i full throttle tacking allway to red line it will pop between shifts will this mess up my engine. I also have 2.5 down pipe and no exhaust. also at night you can see a flash
Old Jan 5, 2009 | 06:13 PM
93turbo16's Avatar
Default Re: back fire during shift is this normal
What system are you tuned with?
If it has ignition cut you might be hitting the limiter in between shifts which might cause a little pop between shifts.
Old Jan 5, 2009 | 06:27 PM
ashb82's Avatar
crome
Old Jan 5, 2009 | 06:28 PM
ashb82's Avatar
so no ignition cut
but i tuned it myself
digital sol
Jul 17, 2006 03:10 PM
ImportMotorSpec
Mar 21, 2006 05:24 PM
CaptainMorgan
Apr 6, 2004 12:19 AM
BoostedH23a1
Apr 2, 2003 09:21 AM
95civicracer
18
Feb 19, 2003 06:34 PM
