Please check my map
How should i scale it
wont i get alot more fuel in some points
could you edit my map, so i can see how it should look
Your map should look like:
Your load columns should not be stacked in 2d mode.
I know what happened
My tps registers -2%
and 96% Full throttle
So i do not hit the col 10
1035MBAR
So i just adjusted the last 3 Columns together.
Would you think that is why my map looks like that
1035MBAR
Yea my TPS read 3 at idle. Weird. Anyway, heres my map for your viewing pleasures.
Keep in mind its just low cam, so ignore the high cam.
Not perfect straight lines, but I like it.
14.6-15:1 at idle.
12.8-13.5 at WOT
14.6-15.5 during most of cruise
Plugs look good.
14.6-15:1 at idle.
12.8-13.5 at WOT
Plugs look good.
You must never take anyones "advice" on timing adjustment. Timing adjustment requires a dyno, and a keen eye for reading plugs. Moreso the first of those two though. This is why correctly tuning a car on the street is totally impossible.
Tuning timing for maximum power requires a dyno yes, but tuning timing for driveability does NOT require a dyno. On the same note, very few tuners I know of tune part throttle timing on a dyno anyway. Some do, yes, but not all and maybe not even the majority. Also, unless its a load bearing dyno, its impossible to have real world conditions simulated on a dynojet.
For WOT, yes tuning timing on a dyno is important, not necessary, but important. Running 1 degree less on the street than you would had you had a dyno isnt going to hurt a darn thing.
Plug reading is a simple and LOST art that would save hours on the dyno and make it what it was meant for, Fine Tuning and Slight Adjustments, not the entire tune.
As for WOT, yes, most people just tune the last 2 columns for WOT. I know sometimes I put the pedal to the metal and I still end up around -1" vacuum, which would put me between columns 8 and 9 in Crome, but for the most part, its the last 2.
Also, ignore people who say that columns 7 and 8 are unimportant. EVERY datalog I have ever done has touched at least portions of columns 7 and 8, so i figure if I am ever in that column, it must be important. Some say interpolate from 6-9, and thats what I did, but I still monitor it.
I recommend making some kind of a "det can" and learning how to properly use one using that, as it will help you with both part and full throttle timing
Funny thing is not one comment yet on my map. Ah well. SHoulda made my own thread/
I am going to have to disagree sir. This is the 'zeitgeist' that has flooded message boards with bad info in order to pay shops for dyno fees.
Or even better, what if you are using a stock based ECU program and that number in your ignition table isn't actually your timing advance value? How sure are you?
My friends make fun of me for how much I pull my plugs. The neighbors think my car is constantly broken cause I always have the hood up. Personally I have only used 1 wideband as its given me no problems.
Ah the wonderful world of datalogging. I do constantly tell people to make sure their ignition timing is at stock (usually 16* BTDC) before tuning timing via the ECU, and for the most part, all values datalogged are VERY close to what they actually are.
You don't know what they actually are. Unless you are tuning on a dyno and have a fast enough eye with a timing light on the crank pulley at 8000 or more rpm you cant tell me that the plug is firing 16btdc at 20 psi (or which ever rpm and load point you want above idle)
Take a Hondata map with a car you dynoed, take ALL of the timing values from S300 and put them in AEM or Motec and see if it makes the same power. All of your corrections and final datalogged timing in OE based computers is not always correct either.
People pay good money for reliablilty. OE computers have too much mystery interms of comps you can not control.
To OP. Do not focus on tuning "2 columns" shape the WHOLE map to what your car needs. Fuel maps should always look your tq curve if you are not tuning off of a duty cycle table. You will find your fuel table will look very similar to your TORQUE curve if things are correct. Again, another reason to use a dyno.
did some tuning tonight
3rd gear for high rpm pulls
and 4th for low
tuned for about 13-13.5 AFR
What is weird is, if i do a 3rd gear pull, looking at freelog, data view, it shows LEAN as much as 15:1 ARF.
Buy my lc1 wideband reports 13:1 ARF
could you explain what is happening?
Also in the low cam, i have data in 1035Mbar colum
but in the high cam, i do not hit that col
Could you advise me whats going on
and 4th for low
and 4th for low
and 4th for low
