running lean???
Old Nov 12, 2008 | 11:03 AM
BlakeJ53's Avatar
Default running lean???
I had a fuel flow problem on on my 90 crx si converted to OBD1 with a b16 that was causing the car to lean out and die, so I made a new fuel feed line and fixed the restriction problem. But the wide band and narrow band sencors are running lean like 20 to 1 . Some thing like that. This is all at idle ,I have not driven the car. I have tried 3 sets of known good stock injectors and 3 differient ecu's 2 chipped and one stock. Still the same result. No checkengine codes. I have also tried DSM 450's and a corresponding chip and it is still running lean. My best result was a stock PO6 with saturated 240's it some times idled at 14.7. But it would eventually run lean. Help
Old Nov 13, 2008 | 02:41 PM
threeplugs's Avatar
Drive the car and inspect the plugs right after to get a visual determination on the fuel mixture. The wideband could be reading incorrectly.
Old Nov 13, 2008 | 07:56 PM
BlakeJ53's Avatar
Default Re: (threeplugs)
The electrodes are white.
Freeltec
Apr 24, 2007 09:52 AM
redlseg
12
Aug 12, 2005 04:44 AM
JDM KING
14
Sep 20, 2004 10:59 PM
mario82686
14
May 7, 2004 09:11 PM
88crxvtec
Jun 26, 2003 01:26 PM
