noob? after datalogging...
Old Dec 11, 2008 | 06:50 PM
ONE*SICK*FERIO's Avatar
Icon2 noob? after datalogging...
what's the first thing you look at??
Old Dec 11, 2008 | 09:19 PM
mtber's Avatar
1. Make sure you have a wideband oxygen sensor input & calibrated into what ever ems you are using.
2. Monitor intake air temperature, coolant temperature, error codes.
3. You monitor air fuel ratio versus rpm versus load & make changes appropriately.
4. On some vehicles you will monitor knock, (not honda/acura bseries as the knock sensor sucks).
5. Ignition timing versus load/versus rpm etc....
The list goes on.
Old Dec 11, 2008 | 10:49 PM
1. i do plx to s300 i can datalog a/f ratio
2.ok
3.how about this found on hondata s300 (show estimated change in fuel to reach target lambda)? should i use it
4.disable
5.ok
thanks
Old Dec 12, 2008 | 06:20 AM
mtber's Avatar
2.ok
4.disable
5.ok
thanks
You can set target lamda parameters & use "auto tune" suggestions to make modifications, however I recommend using datalogging & common sence.
xxdevilzeroxx
Engine Management and Tuning
Oct 15, 2009 11:34 AM
V8MeatHead
Jan 18, 2006 01:26 PM
9341civic
Jun 1, 2005 06:47 AM
MintyDip
Aug 21, 2002 08:11 AM
