P28 w/ a burned circuit board. What's burned?
I picked up this P28 ecu earlier today and forgot to open and inspect it before handing over the cash. I got home and popped it open to find some part scorched along with the circuit on the opposite side. I plugged it in and my h22a started right up. It seemed to rev smooth, and drove around the block with no problems and no check lights. I haven't attempted to get it into vtec or redline because I don't trust a stock p28 to run it.
Any ecu experts have an idea of what the circled areas are, if they will cause any problems, and if I should keep the ecu and socket it, or junk it and buy another?
Thanks!
I apologize for the pics, but my camera isn't great and the pics get blurrier as I get closer.
Thanks!
It does have Q31 written vertically next to it and R135 below it.
Would I need to replace the q31 transistor, or remove it altogether? Do you think running the ecu like this would damage any sensors on the engine, or is it more likely to just run like crap?
Thanks
Thanks
eka11day
Engine Management and Tuning
04-12-2011 10:32 AM
