2,5bar MAP Sensor with K-Pro
Old Dec 28, 2008 | 02:24 PM
mrx's Avatar
mrx
Default 2,5bar MAP Sensor with K-Pro
Hallo,
can someone tell me what boost table i have to choose when using a 2,5bar Motorola MAP Sensor on a K-Pro?!
The normal boost tables only go until 1800mbar
the 3bar boost tables up to 2900mbar which is more then the 2,5bar map sensor is capable of... and the 5bar tables go up to even higher pressures.
which map do i have to use? 3bar and ignore the higher columns?
or could i calibrate the column pressures of the 3bar boost maps so that they max out at 2500mbar?
best regards
Old Dec 28, 2008 | 05:28 PM
mtber's Avatar
Default Re: 2,5bar MAP Sensor with K-Pro
Use the 3 bar tables & ignore the higher columns or simply re-scale the load columns etc.
Old Dec 29, 2008 | 06:30 PM
sander's Avatar
2.7(p/t)
Yeah, you can re-scale the load columns to use 250 kpa instead of 300 kpa, to gain resolution. But to be honest I would just use the 300 kpa tables (3 bar) and ignore the rest.
H-allmotorda9
Feb 7, 2010 07:29 PM
Civicman86
Sep 21, 2006 08:25 PM
boostedhatchsi
Mar 31, 2006 05:16 AM
See Are X
Oct 13, 2005 04:10 PM
B16Civic93
Apr 2, 2005 09:39 AM
