Weird leaning out Issue.
Old Nov 5, 2008 | 02:40 PM
shawn69's Avatar
Default Weird leaning out Issue.
Setup
LS/vtec
stock gsr head
stock b18a block
ps9 with 1 wire vtec
turboedit v 3.1.9
dsm 450s
gm 3 bar
I'm just starting to tune my car. I got it to idle fine, when warm.
However if i rev it up the a/f will be around 13, from 1000rpm to 1500rpm, just in neutral no load. At 1500 rpm and about 28inHG it will all of a sudden turn really lean, past what my wideband can read. (over 17:1). So i added more fuel in turboedit at that spot on the map, but the same thing happened. I added almost %30 more fuel in turboedit but nothing changed. So i thought it might be fuel pressure dropping or something like that, i hooked up a gauge and it stays around 44 psi.
The map sensor is putting out the correct voltage, .384 at ~28-30inHg . But i do get code 13, baro. I disabled the code in turboedit, but it will turn back on after like 10 seconds for some reason.
Any ideas of why this is happening?
Old Nov 5, 2008 | 03:35 PM
fumatch's Avatar
Default Re: Weird leaning out Issue. (shawn69)
plugged exhaust?
Old Nov 5, 2008 | 04:31 PM
shawn69's Avatar
Default Re: Weird leaning out Issue. (fumatch)
It's open downpipe... 3"
If the fuel filter was plugged or old, would i still get good pressure but little volume?
Old Nov 11, 2008 | 11:10 AM
shawn69's Avatar
Anyone?
After that spot the fuel is back to normal.
I don't think any ignition map would cause it to go so lean.
Does 27-28 inHg seem like alot to anyone?
could the ecu actually think the car is decelerating and cut the injectors?
Modified by shawn69 at 7:12 PM 11/11/2008
Old Nov 19, 2008 | 01:20 PM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
can you post a copy of your map?
badbiddy8
May 19, 2016 07:50 PM
hillbillycivic
29
Nov 10, 2012 04:40 AM
dominate9
Nov 29, 2003 10:42 AM
jetpilot
Sep 4, 2003 08:37 PM
