Basemap almost undriveable
Old Jan 9, 2009 | 10:06 PM
zach1288's Avatar
Default Basemap almost undriveable
I installed a turbo on my car and bought a Phearable chipped ECU with basemap. The car is almost undriveable. I cant get it tuned for a few weeks and have to drive to school. It idles fine but in between shifts and giving it gas it cuts out and is absoluty terrible to drive? Is their something wrong with my base map or is this how a basemap is?
Old Jan 10, 2009 | 05:55 AM
mtber's Avatar
Default Re: Basemap almost undriveable
Perhapse the issue is something else besides the basemap.
Do you have a wideband installed in the vehicle ?
Are you throwing any codes ?
Are you running low or high impedance injectors ?
Are you running a resistor box ?
What map sensor are you running ?
What map sensor was the ecu mapped for ?
Old Jan 10, 2009 | 06:36 AM
zach1288's Avatar
Do you have a wideband installed in the vehicle ? No
Are you throwing any codes ? No
Are you running low or high impedance injectors ? High
Are you running a resistor box ? No
What map sensor are you running ? Stock
What map sensor was the ecu mapped for ? Stock
Old Jan 10, 2009 | 06:47 AM
mtber's Avatar
Without a wideband installed in the vehicle it is difficult for us to remotely determine what air fuel ratios the vehicle is running which maybe contributing to your issues.
What size injectors do you have ?
What was the full name on your order ?
Old Jan 10, 2009 | 07:27 AM
known's Avatar
every basemap i have ordered from phearable has been fine
Old Jan 10, 2009 | 07:56 AM
mtber's Avatar
You and hundreds of our customers have never had issues, however there are instances where issues may occur with a basemap. Generally we have seen the issues when a customer installs something incorrectly such as a map sensor, resistor box etc.
Old Jan 10, 2009 | 08:50 AM
zach1288's Avatar
450cc
Zachary Gordon
Old Jan 10, 2009 | 08:53 AM
mtber's Avatar
450cc
Zachary Gordon
Zachary,
I just looked up your order, everything looks to be correct. 450cc injectors etc.
I will private message you with a possible temporary solution until you can visit your local tuner for further diagnoses.
Thank You,
John Vega - Phearable.net
b20turbocivic
Nov 9, 2009 07:28 PM
boostedcivicsir
Jul 24, 2007 11:49 AM
bigwill_2004
17
Jun 20, 2006 08:43 PM
ek9 ferio
May 31, 2005 07:49 PM
teg92
19
Jan 20, 2005 01:09 PM
