Disabling IACV in crome?
Old Jan 12, 2009 | 08:12 AM
zach1288's Avatar
Default Disabling IACV in crome?
Can my tuner disable IACV in crome? Is it safe to disable?
IACV is only important for cold start ups correct? Will my car run normal after it is warmed up? I have a y7 and don't want to rewire.
Old Jan 12, 2009 | 12:04 PM
93turbo16's Avatar
Default Re: Disabling IACV in crome?
It isn't just used for cold start ups. It is used all the time.
In almost ALL cases you want to keep the IACV. If you disable it in crome.. which only disables the code it will usually have a rough fuel cut or hesitation around 1800 rpm.
So IMO you should try to either switch to a Y8 manifold or something with a 2 wire IACV.
Old Jan 12, 2009 | 03:45 PM
zach1288's Avatar
I am getting tuned in a couple days i don't have time to switch. If i switch in a few weeks will it effect my tune?
Old Jan 12, 2009 | 04:20 PM
zman's Avatar
i've seen nothing but bad news using the disable IACV feature in crome, weird **** happens and it hits a really low rev limit.
You can make the car run without one, but you'll have to have it hanging there plugged in to not get the IACV code.
Old Jan 12, 2009 | 04:24 PM
zach1288's Avatar
So if i don't disable it in crome will i still have weird problems until i switch to a 2 wire setup?
Old Jan 12, 2009 | 05:58 PM
mtber's Avatar
Correct. Either switch to a 2 wire setup or switch to an engine management solution that doesn't have issues with a disabled iacv.
JDM215
19
Jan 24, 2011 07:45 PM
efhondaracer27
Jun 1, 2010 02:44 AM
goofyej6
21
Aug 16, 2006 07:10 PM
my car sucks84
13
May 21, 2005 06:53 AM
