Need ECU help.
Old Dec 5, 2008 | 05:17 PM
candyblueta's Avatar
Default Need ECU help.
Ok i just got a 94 Integra LS 4dr and to make a long story short, its been converted to a 5spd by the previous owner. It has a PR4-A11 ecu in it and im pretty sure thats the wrong ECU for a 94 5spd,... do i need a P75? what was the PR4-A11 used in? is that the correct ecu in it? any help is needed... thanks.
Old Dec 5, 2008 | 05:27 PM
GhostAccord's Avatar
PR4-A11 came in the USDM Integra GS 5 speed w/B18A Non VTEC
Old Dec 5, 2008 | 06:26 PM
ok so what do i need. is the ECU gonna have to match the transmission???
Old Dec 5, 2008 | 06:28 PM
like is it possible that the previous owner swapped in the PR4 b/c the trans came off a 92-93?? so if i put a p75-a01 is it going to not work??
Old Dec 6, 2008 | 03:22 AM
The PR4-A11 should work just fine. You don't have to match a specific manual ECU to a manual transmission. The ECU has no outputs for a (TCU) transmission control unit like the Auto ECUs do.
The original owner probably swapped the PR4 because it was the easiest manual ECU to find. Or he had it laying around. Even though he could have kept the stock ECU and converted it to manual???? Much cheaper in the end. A PR4 works the same as a P75.
Are you having any problems with your car or are you just chasing part numbers to make sure they match?
Old Dec 6, 2008 | 06:35 PM
weel im throwing a bunch of codes... like a Tcc code and **** for an automatic
Old Dec 6, 2008 | 06:44 PM
Are you sure it's a PR4-A11 and not a A51 or A71 because the A11 indicates that it is a 5 speed ECU. Do you know if the ECU has been altered in any way.
Can you post up some pics of the ECU? External and with the cover removed.
Old Dec 7, 2008 | 07:56 AM
HiProfile's Avatar
If you're getting auto CEL's, it was probably changed to work for an automatic. OBD1 Honda ecu's can be modded to auto/manual by changing a few resistors, maybe the person thought an auto car needed it to work as an auto ecu, despite the 5-spd. I find it odd it has that ecu, since the stock P75 it had would have worked fine by changing 3-5 little resistors.
Old Jan 8, 2009 | 07:34 PM
red91efhatch's Avatar
Default Re: Need ECU help.
I'm using a PR4-a11 with my b18a swap and it works fine.
MeIngGM
Apr 10, 2019 07:42 AM
ramonjones16
Jul 27, 2009 12:13 AM
bb4socal
Dec 4, 2008 11:31 PM
