Hondata S300, basic how too
Old Nov 6, 2008 | 10:35 PM
Tyconway's Avatar
Default ,
Old Nov 7, 2008 | 05:24 AM
mtber's Avatar
Default Re: Hondata S300, basic how too (Tyconway)
Install the smanager software, then click on the help tab & start reading :-)
Old Nov 7, 2008 | 11:02 AM
98vtec's Avatar
moderator emeritus
http://hondata.com/stech.html
Old Nov 7, 2008 | 11:57 AM
98vtec's Avatar
moderator emeritus
there is a serial number that needs to be entered into s300 for it to work, yes?
thats how neptune RTP is and i would imagine they are much a like in that essence.
Old Nov 7, 2008 | 01:22 PM
mtber's Avatar
Default Re: Hondata S300, basic how too (98vtec)
Incorrect. You don't need a serial number.
mtber's Avatar
Originally Posted by Tyconway
well i downloaded the version of smanager off of hondatas website on my computer tat my home and under help, i have a contents button, theres everything i need..
on my laptop its not there. Do i have an older version on my laptop? is that why i'm having problems with it maybe?
It sounds like your laptop may have issues...
The help files are all there on even the later versions of the smanager.
Old Nov 8, 2008 | 02:07 AM
inspector01's Avatar
When it is running, look at the sensor readings and see if any of them are not reading correct.
What is it doing at idle?? Play with IAC duty cycle, and the other idle settings.
Old Nov 9, 2008 | 09:01 PM
mtber's Avatar
Default Re: (Tyconway)
its not idling, you have to hold the gas on to keep it running.... this is probably like the 15th engine ive put in and ni have never had this problem. Been trying to figure it out for a month. Its a built Ls Vtec, 9:1 comp ratio, .05mil over sized valves and pistons, gsr head, stock cams, all the same sensors that came off my gsr swap that ran perfectly. Even with stock injectors on a gsr map, it should start up normal and idle. But in my case that doesn't happen.
Is this with high impedance 240cc gsr injectors installed ?
Do you have a resistor box installed also? You shouldn't run a resistor box on high impedance injectors.
Double check your timing belt to make sure everything is at tdc.
Old Nov 10, 2008 | 08:14 AM
mtber's Avatar
So even with another ecu & s200 it still doesn't idle ?
Old Nov 10, 2008 | 01:41 PM
mtber's Avatar
another hondata unit, and stock gsr computer, same boat.....
Time to start checking all your wiring man.
Old Nov 11, 2008 | 04:42 AM
mtber's Avatar
Complete a compression & leak down test. Something sounds off.
Old Nov 11, 2008 | 01:13 PM
Tyconway's Avatar
Default Re: (mtber)
180 across all cylinders, a machine shop built the engine anyways...
Old Nov 11, 2008 | 06:16 PM
mtber's Avatar
My suggestion would be to tow the car to a local tuner & have him examine the issue.
It sounds like it could be mechanical or electrical at this point.
Old Nov 11, 2008 | 07:08 PM
Tyconway's Avatar
Default Re: (mtber)
yea jim at motorvations said that it just needs a tune so its gonna be on the dyno in a few days.
b18c_5
Engine Management and Tuning
Jul 6, 2010 09:41 AM
EfSedanLove
Jul 1, 2008 12:29 PM
Acura_I-RS
Apr 7, 2003 07:44 PM
