code 10 and 4 ????
Old Dec 20, 2008 | 01:54 PM
t57b18's Avatar
Default code 10 and 4 ????
got the swap done last night (h23a )started right up and then the cel came on . so today i checked the cel and it was code 4 and 10 so code 10 was fixed (replaced iat ) now for code 4 (crank angle sensor) . im useing a p28 chipped with the same tune the previose owner gave me witch he used in a chipped and converted p06 with my p28 code is throwed and with a p75 chipped ecu it is fine . Is the p28 i have bad any help .
Old Dec 20, 2008 | 02:01 PM
Duane_in_Japan's Avatar
Make sure the wires are good from the computer to the sensor and back to the computer, if all checks good, then I am afraid you will need a distributor or sub assy to save money, only get OEM new or used or reman but not Aftermarket.
Ohming the sensor is not a good final test, you need an oscilloscope to see what it is doing to be sure, it also could be intermittent.
Geis
Dec 17, 2015 11:20 AM
RVCA97
10
Apr 12, 2006 10:09 AM
Topdawgg
Aug 11, 2005 10:40 PM
enigma94
Sep 17, 2004 08:59 PM
98HB
May 10, 2004 07:26 PM
