vtec problems
Old Nov 9, 2008 | 08:17 PM
lee0149's Avatar
Default vtec problems
i got a 99 si. stock basically, s2k manifold, headers,intake. when v-tec kicks, it dont pull as hard anymore. first it was working fine then one day my clutch ran out and i switch it to so cheap stuff on ebay f1 and flanza fly wheel or somthing. i broke in the clutch putting like 500 miles and now when i floor v-tec is no strong. i dont think the clutch have anything to do with it but is it? any help would be fine. i changed spark plugs,oil,wires,regulator,fuel pump and theres no difference. note when v-tech kicks and hit like 6-7 it makes a noise like air is getting force out of something. maybe the values?
Old Nov 9, 2008 | 08:55 PM
mtber's Avatar
Default Re: vtec problems (lee0149)
Your clutch/flywheel has nothing to do with your clutch.
Is your check engine light on? If so, check your malfunction indication codes & get back to us.
Old Nov 10, 2008 | 08:19 AM
lee0149's Avatar
Default Re: vtec problems (mtber)
yes its on ill check it today but before, it was on and was still fast.
Old Nov 10, 2008 | 11:04 AM
lee0149's Avatar
well i did a check engine test and it said
1.low oil pressure
2.block oil passage
3.failed VCT oil control value
so how do i fix these? i only know how to but things on and apart no fix=(.
avotegra
Apr 29, 2009 08:03 PM
HONDRETTI
Oct 25, 2008 09:46 AM
zeth_an
Oct 23, 2005 10:14 PM
preludeshdriver
Aug 26, 2005 09:27 PM
spoon-itr
Jul 9, 2004 04:57 PM
