Primary OBD1 o2 senor same as Primary OBD2 sensor?
Old Jan 15, 2009 | 11:58 PM
wakaranai's Avatar
Default Primary OBD1 o2 senor same as Primary OBD2 sensor?
So at this point, from the research I have done, it looks like the OBD2 primary and secondary sensors are identical with the exception of length (secondary is longer) and the secondary also has a grommet to seal the underbody from moisture.
Now, I have access to a bunch of 4 wire OBDI primary o2 sensors and I was wondering if I could use two OBD1 primaries for my OBDII car. Is this doable?
The plugs look identical and they are both 4 wire sensors.
Any input greatly appreciated.
l1l_r1cky
Feb 28, 2012 01:27 AM
724chris
Jan 23, 2010 07:04 PM
SH
Dec 3, 2007 08:57 PM
redsolturbo
Jul 23, 2007 07:08 AM
Del_Slowest
Oct 25, 2003 01:22 PM
