Help with S300 ITB map
Old Dec 2, 2008 | 07:21 PM
Suzukii's Avatar
Default Help with S300 ITB map
Engine runs very well on WOT. During light throttle, tps ranging 10% to 30% at rpm between 4500rpm to 7000rpm motor misfires and power is down. What can be the cause of this?
light throttle up to 4500rpm is fine, but once the rpm goes above 4500rpm, it misfires badly and power is down. Once i depress the throttle 100% misfire goes away and power is restored and as soon as throttle is released back to 10% misfire starts again.
What can be the problem?
Old Dec 3, 2008 | 05:54 AM
mtber's Avatar
It could be an over-rich or lean condition.
Without providing an accurate datalog file & your s300 calibration nobody would be able to tell you what the issue is.
Your best bet is going to be to have an experience hondata tuner check out the vehicle.
blackeg
Engine Management and Tuning
Aug 19, 2013 05:30 PM
crxtc76
19
Oct 21, 2006 10:25 AM
boostincoupe
Sep 3, 2005 01:54 PM
notstock93
Sep 1, 2004 09:20 PM
GruvyTune
Nov 1, 2001 02:02 PM
