AEM UEGO
Old Nov 7, 2008 | 10:27 PM
DelSolMarine's Avatar
Default AEM UEGO
When i was being tuned my car was reading 11.3-11.5 in full boost according to my tuners recently calibrated wideband. I have the AEM UEGO and it use to read properly on my old setup and now it doesnt. could my aem sensor being going bad? is it possible that my old "leaking oil" turbo could have damaged the sensor from oil getting on the sensor?
Old Nov 8, 2008 | 03:48 AM
xenocron's Avatar
Default Re: AEM UEGO (DelSolMarine)
If you have a lot of oil in the exhaust, yes that can definitely wear out the sensor prematurely.
Old Nov 8, 2008 | 11:41 AM
93TSiguy's Avatar
Default Re: AEM UEGO (xenocron)
Yeah you might as well replace it... they only run 80 bucks new from any performance shop i just got a new one myself... race gas kills it too. Its a Bosch sensor.
PS- i just joined this site 5 mins ago... how does this rating system go? this site told me if I don't lose points right away after 5 days they will give me full status so i can post a classified ad.... I have a set of 450cc Blue Top Injectors off my 93 Talon TSi AWD. Really i just need to sell them so they aren't laying around in a bag. I just want to post an ad for $70 shipped. Thanks... somebody please let me know so i can get the full access thing this week and post it.
Old Nov 8, 2008 | 12:20 PM
NJIN BUILDR's Avatar
Default Re: AEM UEGO (93TSiguy)
So instead of following the rules that you have clearly read,you post an add in a tech section.
Old Nov 8, 2008 | 08:54 PM
Default Re: AEM UEGO (NJIN BUILDR)
thank you for trying to sell something of your own in my thread i appreciate that... moron...
thanks for the input i will be ordering another. it says 17.0 at idle and it just doesnt make sense
Old Nov 8, 2008 | 09:10 PM
The AEM widebands aren't known for being constantly accurate.I am using a NGK wideband that was recommended to me.It is very consistent.It's not uncommon to see widebands reading 16-17:1 at idle.It doesn't take much fuel to change the idle a/f ratio.
Old Nov 9, 2008 | 09:28 PM
really so what do most people recommend as there widebands that are accurate. id like it to be a gauge like what I have so it looks relatively clean. i really like the aem gauge i just wish it was more accurate.
Old Nov 10, 2008 | 06:16 PM
baller status's Avatar
Mine has been perfectly accurate in the year that I have been daily driving on it. I know it's accurate because it matches up with my smog readings (you can use them to calculate your afr).
I know of dyno shops that use them for tuning.
Old Nov 19, 2008 | 06:09 AM
ReDemoN's Avatar
DixielandImports Please
Mine stays at 14.8-15.0 All the time.
And the car is running really rich.
The plugs are wet and black.
So I dont know whats up with my AEM.
Old Nov 19, 2008 | 05:32 PM
kicked25th's Avatar
of course i read this AFTER i buy one.
Old Nov 20, 2008 | 07:02 PM
Tyconway's Avatar
yea my AEM sensor went bad on me also...
Old Nov 24, 2008 | 10:16 PM
SuperTwinz's Avatar
FYI Bosch makes the UEGO sensors not AEM. AEM only covers products they make, so if you're running too rich, mounted the sensor poorly, driving around with a bad turbo, or a bad tune, the sensor will prob crap out on you pretty fast and AEM will not cover it.
Old Nov 24, 2008 | 10:20 PM
SuperTwinz's Avatar
Really? AEM > NGK: http://www.fordmuscle.com/archives/2...tout/index.php
Old Nov 25, 2008 | 03:42 AM
That "test" doesn't get the same results as my real world experience.Many others have have also said that they don't agree with those test results.I think the NGK that I am currently using is a far better unit than the AEM I was previously using.I don't think I am alone with that opinion.
Old Nov 25, 2008 | 10:40 AM
SuperTwinz's Avatar
I've used the AEM unit for over 4 years now and replaced the sensor once. Many will agree that the AEM UEGO is worth every penny. But then again it's all preference. Hey if you like the NGK then it's all gravy. Many will say the Innovative is better then any wide band out there. It might be, but I'm happy with my AEM unit.
Old Nov 25, 2008 | 05:28 PM
Mirage's Avatar
The sensors will start reading incorrectly if they get oiled down from a bad turbo or a blown motor. Replace the sensor and all will be fine.
The best way to think of the life of the sensor is pair it with your spark plugs. On OEM cars they will both go 100,000 miles. But if your car consumes spark plugs then it's also consuming 02 sensors. they both get fouled by the same stuff and at approx the same rate.
You can find them for around $65 each all over the place (AEM 30-2001)
http://www.google.com/products?q=aem...oducts&show=dd
IMO You cant go wrong with the AEM. It's as accurate as the best out there and a heck of allot cheaper to buy. ==> http://www.fordmuscle.com/archives/2...tout/index.php
Old Nov 25, 2008 | 05:30 PM
Mirage's Avatar
Just like your plugs, your O2 sensor is fouled. Fix the problem then replace all of them and you will be fine.
Old Nov 27, 2008 | 04:54 PM
5thgen's Avatar
I had an aem wideband....read about .2 off of my plx wideband I had previously, no big deal.
The problem I had was that I could not get a matched reading from the display itself to the 5v output voltage for datalogging. You can search aem's forum and there are plenty of others out there with the same issue. If I remember it was close to matching around 13-14 afr....but off almost a full point at 10-11 afr.
I then bought a NGK wideband and have not had that problem. Even using the same source voltage to power it up. It shows on the datalog exactly what it shows on my meter.
Old Nov 29, 2008 | 07:23 PM
civickiller's Avatar
me too
Old Dec 4, 2008 | 12:46 PM
kicked25th's Avatar
Well I love my AEM wideband. It seems pretty accurate too according to my plugs. The only problem I know they have is that the computer logs different values than the wideband is showing.
Old Dec 4, 2008 | 07:38 PM
GhostAccord's Avatar
IMO Innovate Motorsports LC-1 is the way to go....The LM-1 WB controller is fully programmable. The LM programmer software makes it easy to custom program the two LC-1 analog outputs. ......Works with almost every data acquisition hardware on the market........
porofek
Engine Management and Tuning
12
May 10, 2019 12:24 PM
DA 4 Lyfe
Feb 2, 2015 02:45 AM
spdrmn
Jun 29, 2012 01:22 PM
RACEPAK
Jul 15, 2011 10:55 AM
Maple50175
Jun 12, 2009 02:06 PM
