boost control with nitrous/aux1
Old Jan 6, 2013 | 11:00 AM
boostedteg4dr's Avatar
Default boost control with nitrous/aux1
Dual stage turbo xs boost controller.
As of now I have a switch to ground the controller. When the controller is grounded it switches to high boost.
I want to enable high boost with nitrous/aux1 parameters.
What output should I use under nitrous control to enable the high boost?
Will I fry the ecu if I use the outputs a15, a20, a17 etc to ground the boost controller witch is fed with 12v on the other side?
Turbo-charged
Dec 13, 2010 06:59 AM
buck02
Jul 17, 2007 09:53 AM
buck02
Oct 12, 2006 05:41 AM
stizzit
Feb 9, 2006 06:17 AM
3.3.3
Jan 8, 2002 02:12 PM
