PCT ecu
Old Feb 15, 2013 | 03:27 PM
chewyv's Avatar
pm4nudes
Default PCT ecu
Is there anymore information on this ecu. Seems like the only good this ecu does is to run on obd2 vehicles with a b16b swap. Other than that it looks like no one bothers with them. But have you guys seen the price on these ecus? $200-$300. Is demand high enough for this ecu to give people a reason to price it so high? Has anyone compared the maps for this ecu and the p73? Anywho I paid $20 for one that I found in the junkyard. Did a little test and ran closed loop on the b18c5 around the block. Idles fine. No bogging. Didn't die. I didn't run the car hard with it since I assumed that I would be running lean.
Old Feb 15, 2013 | 03:52 PM
accorse07's Avatar
Default Re: PCT ecu
PCT and P73 pretty much the same thing. PCT was for CTR and P73 was for ITR. Only difference was 98-01 ITR had the same intake cam as the CTR.
vtecftw
25
May 2, 2007 03:26 PM
red beast
Mar 12, 2007 07:44 PM
winman517
Apr 24, 2006 08:32 PM
kuki
Jan 25, 2005 10:49 AM
