Neptune installed!
Old Dec 19, 2012 | 07:54 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Neptune installed!
installed P06 with Demon in my CRX with the stock D16A6, took 10 minutes, including converting the car to OBD1.
two questions. why can i not read VSS? how do i read CEL codes now?
Old Dec 20, 2012 | 12:30 AM
mouab18c1's Avatar
Default Re: Neptune installed!
You should be able to read your CEL error codes on your laptop if it is connected to the demon.
Old Dec 20, 2012 | 05:53 AM
HRTuning's Avatar
Question about VSS answered on the NepTune forum. You can check codes with the laptop from the tools menu (E is the command key for error codes) or the main toolbar.
Old Dec 20, 2012 | 05:19 PM
thanks all!
Old Dec 21, 2012 | 06:46 PM
98vtec's Avatar
moderator emeritus
good luck. Let us know if you have any questions.
hondacivic97si
Mar 2, 2015 11:20 PM
jackmonk
Jan 13, 2005 05:49 AM
Dino_D
Mar 10, 2004 11:03 AM
HXMan
Nov 22, 2001 08:22 PM
