Motec M4
Old Dec 3, 2012 | 02:46 AM
Rage Cayman's Avatar
Default Motec M4
I an doing an all motor B series with parts I have laying around. I found a MoTeC M4 with harness, and also an AEM Twinfire. Is it pissible to wire these 2 together and use the M4 AUX outpus as IGN inputs?
Old Dec 3, 2012 | 10:51 AM
a1320addict's Avatar
Default Re: Motec M4
Huh? The M400 can be used with (4) ignition outputs and (1) aux output. You have no need to do anything funky for outputs to trigger the Twin-Fail.
Unless you're hell bent on having a crappy CDI on the car, either put K-Coils or a Pro14.
Old Dec 3, 2012 | 02:48 PM
Also Has 4 KSeries , the 1 dedicated Ign output and 3 Aux output will Work for the M4 and KSeries coils? If yes, then I will do that .
Old Dec 3, 2012 | 02:59 PM
As far as I know you can configure either rising/falling, so yes you can.
You have (5) total available outputs, you can use either (1) IGN and (4) Aux 'Distributor', (2) IGN and (1) AUX 'Wasted Spark', (4) IGN and (1) AUX 'Direct Fire COP', etc...get the drift?
http://www.motec.com/m4/m4overview/
raymondpowens
Jun 18, 2017 09:15 PM
ugotdriven
Mar 10, 2011 03:38 AM
BukakkEK9
Oct 15, 2006 01:01 PM
