s300 same p06 and same tune, different results.
Old Nov 25, 2012 | 07:25 PM
rstchris's Avatar
Default s300 same p06 and same tune, different results.
I pull out my p06 with s300 for another p06 with s300 and BBG. Upload my tune and the car wont start. Had to scale my injectors down by 250cc just to get it to start and still running lean. It's so far off I am not even able to drive the car. I tried my tune on my buddys p28 in my car and similar results. My question is, **why are the ecu's so inconsistant from one another?** Other systems I have used don't have this issue.
Old Nov 25, 2012 | 07:54 PM
mtber's Avatar
Default Re: s300 same p06 and same tune, different results.
I have never seen such variances between ecus.
It sounds like the original ecu which your calibration was made on may have an issue.
Old Nov 25, 2012 | 09:53 PM
rstchris's Avatar
My original p06 had my 750cc injectors scaled as 750, when I swaped to the other p06 I had to scale them as 500 just so the car will start. I have seen it with 3 ecu's now, just wondering why.
Old Nov 25, 2012 | 11:37 PM
eDm cRxXx's Avatar
Did you update sManager i the mean time?
My experience is that there is a huge difference between the "CD-rom" version of hondata, and the newest version.
Old Nov 26, 2012 | 07:26 AM
rstchris's Avatar
The software was the same for both ecus so it should not have made a difference. It was 1.6 something I think. I can't be the only guy who has seen this before.
Old Nov 26, 2012 | 08:25 AM
raverx3m's Avatar
Damaged circuits on ecu?
Cold solder?
Old Nov 26, 2012 | 10:11 AM
xenocron's Avatar
Unless there is an issue with the injector drives on one of those ECUs, there should be no difference.
Old Nov 26, 2012 | 05:50 PM
rstchris's Avatar
I have also noticed something even more wild. My warmup cycle is way rich to the point that I am pulling -40% all the way to 170* then once the engine heat soaks it slowly gets normal. Hey Xenocron, maybe I can ship it to you for testing. I also want BBG in my "known good" ecu. PM me.
Old Nov 27, 2012 | 03:40 AM
xenocron's Avatar
Yes we can do that, all details are on the website in the services section
www.xenocron.com
Old Dec 7, 2012 | 01:40 PM
rstchris's Avatar
Turns out the MAP sensor is wacky. It's a Crespo 4 bar and on cold start it reads 16" of vacuum on s300 while the gauge reads 20" then once it's heat soaked s300 reads 24" @ idle while the gauge still reads 20"
Time to get a tried and true sensor.
Old Dec 7, 2012 | 05:07 PM
mtber's Avatar
I have seen crespo 4 bars fall apart on the dyno. They totally suck.
I refuse to tune a car with one. I will only use Omni Power or Hondata map sensors.
Old Jan 3, 2013 | 05:34 PM
rstchris's Avatar
I'm using a GM 3bar. With the values I found on this site the sensor works perfectly and needed minimal tuning.
408EJ1
Engine Management and Tuning
Mar 26, 2011 07:23 PM
chocolatesk8er10
Nov 19, 2008 01:49 PM
integ92gsr
Jan 18, 2008 07:33 AM
blackonsilver
Nov 22, 2007 11:02 PM
fastludeh22
Feb 13, 2003 12:24 PM
