AEM tru boost question
Old Mar 12, 2013 | 07:21 PM
bumblebeehatch's Avatar
Default AEM tru boost question
Does anybody know if the AEM Tru Boost can lose its settings memory? Like if it was unplugged while on or something?
Old Mar 13, 2013 | 07:54 AM
Rtype16's Avatar
Default Re: AEM tru boost question
No it will not lose its settings. What is wrong? If you can only go higher in boost and not lower make sure the scramble boost wire is not grounded.
Old Mar 13, 2013 | 10:27 AM
Well the reason I ask is because I've been chasing a boost spike problem. I've narrowed it down to either the tru boost solenoid or the gauge settings. My only problem is that when my car was tuned with the solenoid everything was fine, boosting right at 14-15psi (wastegate spring) then one day it started spiking. Idk how to change settings so I know I havent changed any settings. But the other day I took the solenoid out and ran a vacuum line from the compressor housing to the side port on the wastegate and it boosted right at 14.4psi (where it should be.)
So does that mean the solenoid is bad?
OR does that mean the settings on the gauge changed? Also I noticed when the gauge was in "off" mode it was still spiking instead of running straight wastegate pressure like its suppose too.
I tested the solenoid according to this...
My solenoid worked fine, blew air through each port how its suppose too when energized and de-energized
Old Mar 13, 2013 | 11:33 AM
accorse07's Avatar
If the gauge is in OFF mode, your only going to boost your spring pressure. If there is spiking, it would not have anything to do with the boost controller but could be because the vacuum lines are too long.
Old Mar 13, 2013 | 04:05 PM
It was spiking in "off" mode.. But it wasnt spiking when i had the car tuned, I didnt change anything.. Then one day its started spiking.. so it cant be the vacuum lines..
Old Mar 14, 2013 | 08:30 AM
accorse07's Avatar
How many days was it from the tune to the day you started getting the spiking problem?
Old Mar 15, 2013 | 06:21 PM
Got it tuned the beginning of November, started spiking probably mid February
Old Mar 15, 2013 | 09:19 PM
odz-fab's Avatar
maybe check all your vacum lines for wear or pin hole leaks... i used to run an old turbonetics wastegate that after a few months would need to be cleaned of carbon build up around the stem cuasing it to not open all the way
Old Mar 16, 2013 | 07:18 AM
I have checked all the lines, and i also checked the wastegate ports.. they were both free and clear
Old Aug 3, 2013 | 03:27 PM
Okay so i got my car to stop spiking with my tru boost in the "off" setting. But when i go to settings A and B it reads er5. Does that mean the solenoid is bad? I havent programmed any settings in A or B yet. Could that be it?
vy3tnamezz
Nov 6, 2008 02:11 AM
Horseofcourse
Jul 27, 2007 10:39 AM
Sprayin_civic
Aug 26, 2004 10:35 AM
mattcalica
Jan 17, 2004 02:49 PM
Kamin
Sep 11, 2002 08:46 PM
