Boost target speed table??
Old Dec 9, 2012 | 05:49 AM
DraginX's Avatar
Default Boost target speed table??
I'm just setting up some things in my AEM V1 in my Boost target speed table and would like to bring the break points closer but cannot figure out how to do it. Basically take them from 0-16-32-48 down to 0-8-16-24. Is this possible and how would you go about it. Only thing I can think that would work would be to take the vss calibration in the vss options from 226 to 113. It wouldn't change the break points but wouldn't this essentially make the values worth half what they show?
I know some of you guys must have ways to get it closer.
Another thing I was thinking was when I set up the rear wheel abs sensor just leave double the teeth you would normally leave for more resolution which should also make the numbers closer fudged to be actually double what they are showing.
Any help with this is appreciated, I think we could get a good discussion going about this.
Old Dec 10, 2012 | 03:46 AM
xenocron's Avatar
Default Re: Boost target speed table??
Best to just set it up correctly instead of trying to fudge things.
In Aem Tuner software, there is a breakpoints tab where you can setup those VSS points however you like. Its there in V1 software...i just dont remember to tell you where to look exactly in the software.
Old Dec 10, 2012 | 04:36 AM
mtber's Avatar
Click setup, break points, VSS breakpoints table, graph and edit the graph as needed.
Old Dec 10, 2012 | 04:59 AM
DraginX's Avatar
Excellent, thanks guys!
sanman000719
Dec 1, 2012 06:13 PM
vavoom
Jun 22, 2011 11:26 AM
StrokedPSI
Aug 2, 2004 12:19 AM
Tommyyy
17
Nov 18, 2002 12:12 AM
