Awkward Idle Problem, Need suggestions.
Old Dec 18, 2012 | 12:08 PM
Team_Coast978's Avatar
Default Awkward Idle Problem, Need suggestions.
I have a 96 cx hatch with a b17 swap (b16 head and pistons)
I notice when ever my gas is low my car idles low, like 700-750rpm, someitmes 550-600 .. but it stays steady where ever it's at.
i used to run 87 and it idled low all the time, now i run 93 and it only idles low when my gas is low. If i have a quarter tank or higher, my idle is about 900rpm
what could this be ?? Normal ?? Let me know what ever else information you need.
Old Dec 21, 2012 | 05:33 PM
go-part's Avatar
Default Re: Awkward Idle Problem, Need suggestions.
It sounds like you have a weak fuel pump. Try using a gas treatment chemical and see if that fixes your problem. If not id suggest a new fuel filter.. then work your way up to a new fuel pump
Old Dec 21, 2012 | 06:55 PM
98vtec's Avatar
moderator emeritus
or you can test the fuel pressure and see if there are any issues there.
Michael Booth
Jan 22, 2018 11:26 AM
Team_Coast978
Jan 3, 2013 02:43 PM
joshsayswhatt
19
Sep 5, 2009 04:48 AM
PY TYPE R 483
Jan 24, 2006 06:28 PM
ransack
Oct 7, 2002 12:10 AM
