need help with tune
Old Feb 21, 2013 | 03:34 PM
boostedxcivic96's Avatar
Default need help with tune
ok so i been setting up a base map to take my car to dyno
specs
tuning with crome
b18a1
p75 chipped
450cc black top dual spray injectors
stock everything
t3t4 turbo 68 trim
aem wide band 02 its running at 13.9 14.1 want it at 11.6 - 12.8 cant figure it out
i am getting a knock till 2100 rpms
ignition retard at .75 degree
turbocharger efficiency 180%
battery offet is for 450cc dsm an it reads out
batt [16.0 ] [14.0] [13.0] [12.0] [11.0] [9.0] [7.0]
inj [ 0.19 ] [0.45] [0.55] [0.67] [0.81] [1.22] [1.72]
need help plz any info would be great
any ideas on what needs to be fixed
Old Feb 22, 2013 | 07:10 AM
ChokolAwt's Avatar
Default Re: need help with tune
specs
tuning with crome
b18a1
p75 chipped
stock everything
t3t4 turbo 68 trim
a general rule of thumb for a basemap is to retard .5 degrees of timing per pound of boost, compounded. im not sure if there is a setting in crome but you should switch to straight table timing in boost (makes it easier to tune).
right now, your car would be fine to drive to the dyno assuming you stay out of boost and you really dont have a knock "until 2100rpm."
Old Feb 22, 2013 | 11:42 AM
VegasInvasion's Avatar
I'm Huge In Japan
it's not likely you have knock that low on a stock A1, unless it's rod knock. try retarding your distributor until you can have someone tune it.
Old Feb 22, 2013 | 12:23 PM
i figured out why it was doing the stupid knock my friend put in 5w30 when i told him not to thank god i didnt drive the car it came out like water put in the new oil an its running smooth
alright ill set my base map to .5 per pound see how it goes
Old Feb 22, 2013 | 05:08 PM
ok so now i set my boost retard at .5% an now im getting major fuel cut at 9 psi
Old Feb 23, 2013 | 03:17 AM
grumblemarc's Avatar
The Grumpiest
I'm curious as to why you're pushing the car to 9psi if you should only be basemapping to get to the dyno?
Old Feb 23, 2013 | 11:53 AM
my external wastegate is 9psi
Old Feb 23, 2013 | 11:55 AM
after doing more reading up on basic tuning got the car to run with no fuel cut now at all. so next week it will be at the dyno
Old Feb 23, 2013 | 03:13 PM
Muckman's Avatar
Moderator in Chief
That doesnt mean you have to drive at 9psi...
Set the boost cut to 2psi and keep your right foot out of boost until you get it tuned.
Old Feb 24, 2013 | 05:49 AM
The Grumpiest
Co-sign!!!
Old Feb 27, 2013 | 02:08 PM
ChokolAwt's Avatar
that is the dumbest **** i've ever heard.
Old Feb 28, 2013 | 07:00 AM
then plz tell us sence its so "dumb " . why isnt my motor have a knock sound anymore after adding a thinker oil an after the tune its running strong plz tell us . why my old oil my buddy put in was the same as water coming out of a hose please tell us. don't worry ill wait
Old Feb 28, 2013 | 07:54 AM
kyden's Avatar
because if a stock motor is getting a bottom end knock on the oil recommended for it.. the problem isn't the oil.
Old Feb 28, 2013 | 08:12 AM
The Grumpiest
You can put in a higher viscosity oil like you obviously did and it will only mask the sounds/symptoms. This is an old trick used by shady car salesman. If your engine is knocking you're already screwed. I'm boosted and I run what Honda recommends. 5W30 and it doesn't flow out of the engine like water when I do oil changes either. Now more than likely your buddy put something in with the oil like Seafoam because that **** will have your oil at the consistency of ink.
Old Feb 28, 2013 | 08:44 AM
bisscrac's Avatar
doe doe
Old Mar 2, 2013 | 04:50 PM
swordofdoom's Avatar
Best to just **** in the engine!
Old Mar 7, 2013 | 08:36 AM
siregcivic's Avatar
op send me a copy of your map siregcivic@gmail.com
what is your afr at 9psi ?
Old Mar 7, 2013 | 08:37 AM
siregcivic's Avatar
and if your just tuning or flashing chips per say and do not have a wideband installled... expect your engine to go boom.....
also for basemap i pull .75-.9 per psi of boost until on the dyno i will fine tune ignition map after the fuel map is dialed in
Old Mar 16, 2013 | 11:26 PM
I'm Huge In Japan
0.9* per PSI on a stock B18A1 is absurd. On stock ignition you don't even need to start retarding until 3 PSI. You're just wasting dyno time if you take out more than 0.5*
But since the OP is driving like an idiot on a basemap what's the point in making boost adjustments at all...
flip_ep
Oct 5, 2013 09:01 PM
Oahugrown808
Engine Management and Tuning
20
Feb 19, 2013 06:22 AM
Jimmy
Mar 29, 2011 10:56 AM
RedCd5TX
13
Aug 7, 2009 10:44 AM
vtec_racer_2kgsr
Sep 19, 2006 12:32 PM
