1720 Board ECU NOTEC to VTEC CONVERSION
Old Dec 6, 2012 | 09:50 PM
boostdeliquent's Avatar
Default 1720 Board ECU NOTEC to VTEC CONVERSION
Here is a visual aid I made for anyone wanting to convert their notec ecu based on the 1720 ecu board to vtec. It's not a step by step but I think anyone capable of doing the conversion will get the gist of it. The secondary diagram listed for RM11 comes with the conversion kit if purchased from Moates. I used this most commonly on P05 and P06 ECU's. You do need to be careful though as some later p05/p06 were made on the 11FO board and require a different kit.
Old Dec 7, 2012 | 11:24 AM
SQ is the SQUAD's Avatar
Default Re: 1720 Board ECU NOTEC to VTEC CONVERSION
i was always under the impression that D11 was a 1n4001............
Old Dec 7, 2012 | 10:12 PM
I've always used the ones provided in the kit Moates sells and have never had an issue. Perhaps the difference between the 2 is negligible.
Old Dec 8, 2012 | 05:05 AM
GhostAccord's Avatar
In my opinion the best place for anyone wanting to get into chipping and ECU electronics would be to become a member of PGMFI.org. Great site with a lot of great old school and new trend technical information.
The step by step info for this conversion is available on that site..... along with all the individual part numbers so you don't have to keep spending so much on kits.
as for the diodes, the 4001 is what I would suggest as it has lower peak voltage ratings. However both will work.
Specs on page 2 - http://www.adafruit.com/datasheets/1N4001-D.PDF
blake22
Engine Management and Tuning
May 16, 2011 04:16 PM
yaoming315
Sep 26, 2007 08:34 PM
Joecivic94
Aug 14, 2007 06:52 AM
Jorsher
Sep 5, 2006 07:55 PM
DaMmniTz
Jan 9, 2005 12:03 PM
