p2p ecu for lsvtec??
Old Jan 31, 2013 | 10:26 AM
spun95's Avatar
Default p2p ecu for lsvtec??
I have a 96 integra. It had a b16a2 engine, and gsr trans when i got it. Im in the middle of my first lsvtec conversion, b18b1 bottom and b16 head. I checked to see what kind of ecu was in the car because im obviously going to have to tune it. The teg had a P2P ecu. Which to my understanding is for 96-00 0bd2a civic ex. Will i be able to use this ecu or do i need to get one to match the head before i start tuning?
Old Jan 31, 2013 | 11:23 AM
spAdam's Avatar
Loved
Community Favorite
Default Re: p2p ecu for lsvtec??
You need an obd1 ecu and adapter harness with at least a chip socket. P28 and P06 (w vtec conversion) are the most commonly used. If you purchase a Neptune setup from phearable or similar you can get it preloaded with a basemap for your application.
Old Jan 31, 2013 | 11:37 AM
spun95's Avatar
Thanks for the info! i am probably going to go with a p28
Old Jan 31, 2013 | 11:39 AM
spun95's Avatar
if i use a p72 with a jumper would the check engine light be on because i am not running the gsr intake?
Old Jan 31, 2013 | 11:42 AM
spAdam's Avatar
Loved
Community Favorite
No. IAB's will not throw a code.
auto-union
Apr 9, 2018 09:17 AM
spun95
Jan 31, 2013 07:35 PM
mawkiemarc
22
Feb 28, 2006 12:21 AM
racer_X_123
Aug 25, 2005 09:31 AM
97civcoupe
13
Apr 11, 2005 10:23 AM
