high map at idle
Old Jan 12, 2013 | 03:58 PM
GagnarTheUnruly's Avatar
Default high map at idle
I'm troubleshooting a weak idle/stalling in a 98 LS 5 speed, and my datalogger indicates a very high manifold pressure at idle (470-500 mbar). Anybody know what could be causing this? Am I correct in assuming it is a vacuum leak upstream of the IACV?
Edit: I believe the MAP sensor is functioning correctly as it indicates a correct pressure with the engine off.
Old Jan 13, 2013 | 09:38 PM
Default Re: high map at idle
Bump -- anybody know what could cause a very high manifold pressure at idle? I'm not even sure how the car could maintain a low idle with so much air in the manifold.
Old Jan 14, 2013 | 05:19 AM
Johnny_9's Avatar
vacuum leak?
Old Jan 16, 2013 | 10:15 AM
The valves were too tight. WAAAY too tight. All of them! This is why I do my own work, lol.
Old Jan 16, 2013 | 06:24 PM
xenocron's Avatar
Yeah I was going to say valves or the chance the cam jumped timing.
Old Jan 16, 2013 | 07:27 PM
turbociv910's Avatar
take it to a better mechanic..
Old Jan 16, 2013 | 08:30 PM
It was done by a previous owner.
Old Jan 19, 2013 | 09:01 AM
Gunmetal_B20_Hatch's Avatar
vacuum leak should be pretty obvious. Valve adjustment is another thing and also cam design and cam timing will affect your manifold vacuum.
ketchup
Feb 5, 2009 08:55 AM
88crx-si
Nov 9, 2005 07:01 AM
s1ngle
14
Apr 29, 2005 10:34 PM
civicracer1993
Feb 24, 2003 07:25 PM
Spade
11
Nov 28, 2002 09:35 AM
