P28 Q33 transistor
Old Jan 21, 2013 | 02:46 PM
sicones's Avatar
Default P28 Q33 transistor
I'm trying to figure out what transistor goes in Q33 in a P28 11F0 board, I need it for the A10 output. Can some pop open there P28 and tell me what it says on it. Of course the three P28s I open don't have it. Thanks!
Old Jan 21, 2013 | 03:41 PM
mpgmike's Avatar
Default Re: P28 Q33 transistor
Not quite sure what you're working on (I'm new here), but often electronics engineers design a board with more capabilities than needed for flexibility. The fact the holes are soldered shut suggests no transistor is required to function for what it was assembled to do for your application.
Are you having a problem with the board, or just concerned about the empty space?
Mike
Old Jan 22, 2013 | 04:07 AM
sicones's Avatar
Q33 controls the A10 output I need for a nitrous solenoid.
Old Jan 22, 2013 | 08:21 AM
mpgmike's Avatar
It looks like whatever Q103 is might be the same. Essentially, you need to know if it is a NPN or PNP type. Usually, electronics engineers favor the NPN types. If that's the case, a standard 2N2222A is a good default piece.
Mike
Old Jan 23, 2013 | 04:15 AM
sicones's Avatar
I would rather have the correct transistor in place, 2n2222 is pretty old and small signal, no one has a p72 or p28 sitting at there desk with a screwdriver?
Old Jan 23, 2013 | 01:30 PM
sicones's Avatar
Well I found my answer, in case anyone does a search it's the same as Q31 or Q34 which is a SD21780SA.
Old Jan 23, 2013 | 01:58 PM
mpgmike's Avatar
Found it. It's an NPN 50V 1.5W 2A transistor. Digi-Key PN 2SD21780SATB-ND. Unfortunately it's a non-stocked item. PN PN2222ATACT-ND is a 40 volt 1 amp transistor that could be used as an alternative. I retrieved this info from Digikey.com
Mike
Old Jan 23, 2013 | 05:34 PM
sicones's Avatar
That 2222 you referenced is not a good choice the pin configuration is different (EBC) its the wrong package and only 1A Ic. The absolute closest thing I could find is 2SD2138APACT-ND, it has the same 3-SIP package, pin configuration (ECB) and 2A Ic. Anyhow, I already ordered the correct part from Moates.net
Old Jan 24, 2013 | 08:21 AM
mpgmike's Avatar
Good deal! Of course you'll have to keep us updated with the nitrous results.
Mike
Old Oct 29, 2013 | 06:24 AM
vipersal's Avatar
Old Thread, but I have many P28 ecus at home, i will check tonight.
But as I remember this spot is empty.
Old Oct 29, 2013 | 10:20 AM
HondaMotive's Avatar
This spot is empty on most 11F0 boards and most others as well. Maybe it was automatics that had it? Out of 100s Ive chipped Ive seen maybe 2 with it from factory. I add these for S300 installs mostly.
ONEhb2NR
Jul 24, 2005 11:03 PM
turboH22Aakkord
May 13, 2005 11:57 AM
