NA/ ITB tunning.
Old Jan 3, 2013 | 10:38 AM
Elevenseries11's Avatar
Default NA/ ITB tunning.
Right now I'm working on a NA build with my B18C-R and Im splurging for the TODA ITBs... am I going to have to have the AEMS EMS to tune these or some sort of standalone instead of my chipped ECU.
Old Jan 3, 2013 | 03:28 PM
SR20S13's Avatar
Default Re: NA/ ITB tunning.
Why toda? And not say Kinsler itbs?
Old Jan 4, 2013 | 02:00 AM
swordofdoom's Avatar
Just change your fuel maps on the chip. The ITB's suck in more air everything else is the same.
Old Jan 4, 2013 | 06:45 AM
balbowskie's Avatar
i feel stupid but what does ITB's stand for? me lost......
Old Jan 4, 2013 | 07:52 AM
Sleeper.SEDAN's Avatar
Alpha n. Look it up
Old Jan 4, 2013 | 08:03 AM
JKTUNING's Avatar
Both Hondata S300 and NepTune RTP can do hybrid maps and or straight alphaN if you wish.
IMO, it is much easier to tune an ITB car with a hybrid MAP/AlphaN load source setup using the primary and secondary map features of the programs.
It is generally a good idea to have a decent sized vacuum block so you can use the map sensor for light load and idle and then switch to alphaN (secondary map) after a certain throttle percentage or map load.
If you have no idea what I just said in the above post, then I suggest contacting your local tuner of choice and see if they can lend you a hand. ITBs can be a serious pain in the *** to get just right.
Old Jan 4, 2013 | 05:08 PM
GhostAccord's Avatar
ITB's = Individual Throttle Bodies.....
Old Jan 5, 2013 | 03:24 AM
7rrivera7's Avatar
I haven't tuned an ITB setup yet but I understand your editor needs to support alpha-n tuning which uses RPM, temperature and TPS to calculate the amount of fuel to inject as opposed to using the manifold absolute pressure and RPM to calculate the amount of fuel to inject (speed density).
I know Crome supports Alpha-N tuning via it's ITB plug-in but I have not used it. Good luck!
Old Jan 5, 2013 | 05:22 AM
Pretty much all of the software for OBD1 Hondas out there now supports the switch between speed density and alpha-n. And yes at least Crome has the Alpha-N function as well.
Love the MegaSquirt software options, it now has a dual map tuning solution called ITB load mode. Along with the usual engine load type tuning solutions, speed density, mass air flow and alpha-n.
Explanation of how it works here!
likwidchz
Engine Management and Tuning
Aug 9, 2016 05:12 PM
JDM JEFFREY
11
Oct 13, 2009 11:55 AM
Patron
Mar 21, 2004 03:42 PM
01ITR#700
Jun 19, 2003 02:20 PM
