built b81c wont start..
Old Jan 15, 2013 | 12:59 PM
stfuek9's Avatar
Default built b81c wont start..
please help!! fresh built b18c1 turbo tunned on s300 no check engine light!! has fuel to rail and had msd external coil but just replaced it with a stock gsr dizzy that i know works... and still WILL nOT START!!! any ideas?
Old Jan 15, 2013 | 01:14 PM
stfuek9's Avatar
Default Re: built b81c wont start..
Help
Old Jan 15, 2013 | 02:19 PM
b19coupe's Avatar
Engine needs three things to start: compression, fuel, spark.
In order of ease to check:
#1-Good spark at spark plugs?
#2-Fuel injectors pulsing with good fuel pressure?
#3-compression good and valve timing correct?
Old Jan 15, 2013 | 02:33 PM
stfuek9's Avatar
just put new plug new wires, replaced the msd b.s and put a stock dizzy, compression is what it was built to 9;1 it has rc 1000cc injectors and like i said i know it was getting fuel to the rail but not sure about the injectors how can i check that? just pull the rail with the injectors and turn the key?
Old Jan 15, 2013 | 02:57 PM
b19coupe's Avatar
Verify spark at the end of the spark plug wire(after removing it from the spark plug) by inserting a long screwdriver into the end and holding the screwdriver close to a good ground. Have somebody crank the engine.
To check for the injector pulse, there is a special electrical tool with a light bulb that flashes if the injectors are getting a proper signal.
http://www.beachaudio.com/Otc/7602-p...rce=ShareASale
Old Jan 15, 2013 | 04:46 PM
98vtec's Avatar
moderator emeritus
This is HUGE and should be known to anyone asking questions about a car that does not start or a car that is having issues. You have to give us information (complete) with what we are working with. Without actually testing things, all we can offer are possible options. And with a car that doesnt start, the possible options of why it doesnt start are very abundant.
All getting fuel at the rail tells us that the pump is working, just wont tell you if its flowing enough.
You can buy a couple tools and figure out the problem, with some help typically less than the cost of a diagnostic. If you want to learn a few things, i would go that route. If you want your car fixed in a timely manner, find the proper automotive shop.
Old Jan 20, 2013 | 07:25 PM
Boost4Breakfast's Avatar
to check if the injectors are firing:
take a long screwdriver and set the end on the injector body. place the handle up to (touching) your ear. have someone turn the key to turn the engine over. There will be an audible "click" every time the injector opens
Maidumechanic
Feb 14, 2013 05:39 AM
civic46
11
Sep 12, 2010 05:25 PM
A2gt35r
Sep 30, 2007 06:26 PM
hatchdrvr
Sep 27, 2004 02:05 PM
Big_b_69er
Jan 24, 2002 09:07 AM
