B18b1 ebay dizzy help
Old Feb 12, 2013 | 05:31 PM
Cmorcivic's Avatar
Default B18b1 ebay dizzy help
i was going to buy a distributor from advanced or autozone for my turboed OBD1 B18b1 for the limited lifetime warranty and both stores are only a few minutes away from me, thing is, im not looking to spend 210$ on a distributor that may not need to be replaced... (ive been having this strange on-going issue that i believe is distributor related, more specifically ignition control module, but why replace that for ~50$ when i can replace all of it for ~150?) So, my question is, which of those sketchy, cheap, no name ebay brands is the best? What exactly is ebay "high quality?" And what constitutes "heavy duty?" Here are some links of dizzy's i found, just an example of what im looking at...
http://www.ebay.com/itm/JDM-ACURA-IN...47244e&vxp=mtr
http://www.ebay.com/itm/NEW-IGNITION...88737d&vxp=mtr
http://www.ebay.com/itm/New-Ignition...257228&vxp=mtr
i want something that will last, good quality, new, and within the price range of 100-200$, warranties are also nice... thanks in advanced for the replies...
Old Feb 12, 2013 | 09:25 PM
TheShodan's Avatar
Moderator
Default Re: B18b1 ebay dizzy help
I'd get the better ACCEL upgraded coil from Summit, and call it a day, and forget eBay altogether. The only super important parts other than the cap and rotor is your ignitor, and as long as that fails, why risk eBay?
http://www.summitracing.com/parts/acc-11076/overview/
BAM. why **** around? ...
Old Feb 13, 2013 | 06:15 AM
somalia757's Avatar
Post Re: B18b1 ebay dizzy help
If you price range is $100-200 & the new one is $210 I say go new.
Or junkyard or local forum.. Hell I've even found great deals on Craigslist
Old Feb 13, 2013 | 01:30 PM
Cmorcivic's Avatar
Is the coil and ignition control module two separate things within the distributor? im currently running an msd external coil, because i thought my coil was going bad, but the problem persisted after replacement... i was told that the distributor has an ignition control module and a coil, and i was also told that the ignition control module is located elsewhere in my engine bay... this is frustrating lol, is there an ignition control module, and where is it?
DOHCtorTHRUST
12
Dec 12, 2013 10:20 AM
vteck1ck
10
Dec 17, 2008 07:45 AM
Mattyg2
Oct 18, 2008 07:41 PM
H.A.R.T B18C1EG6
Mar 24, 2006 12:42 PM
bcphatchback
Oct 3, 2005 11:33 AM
