so i have the emanage in my 97 honda accord f20b auto..ecu is a 97 accord ex ecu vtec. tuned by churches automotive tuning in cali. the problem im having is that the car starts when it wants to..usaully doesnt want to start when it warm, when its cold will start up right away.now i never had this problem with the stock ecu. thinkin it had to do with the tune i took it back to churches but the said nothing is wrong with emanage that it might be the fuel pump relay/main relay cause he said he doesnt here the fuel pump turning on sometimes i went home bought another relay swithced it out and still had the same problem. i thoought about something being wrong with the car itself so i switched the emanage and put the stock ecu by itself and it starts up every time..so it has to be the emanage so called churches againg and they said to call greddy but i really feel that it has to do with the injectors not spittinng enough fuel or something...it gets spark and everything if any body could help it will be much appreciated thanks
