TDC code 8 issue, dizzy is good.
Old Nov 27, 2012 | 04:37 AM
Listerofsmeg's Avatar
Default TDC code 8 issue, dizzy is good.
Hi all,
I am currently having an issue with my ecu throwing up code 8 which is TDC. Ecu is a chipped p28, running a B16 NA. We have already tested another known good dizzy with the error still occuring (cleared then retested). I have also tested the resistance on the sensor wires on the dizzy plug which if i recall showed up 400~ohms (i believe normal range is 350-700?)
So i am just seeking a little more guidance to see if anyone else has had a similar issue.
The loom is an OBD2A and the car is a 97 Civic hatch.
Does any of the dizzy wiring go through the "redundant" blue plug on the loom? the one with the blanking bridging panel?
Old Nov 27, 2012 | 06:32 AM
josephcmiller2's Avatar
Check ECU. If not that, then you have bad wiring somewhere.
Posted from Honda-tech.com App for Android
Old Nov 27, 2012 | 06:38 AM
Default Re: TDC code 8 issue, dizzy is good.
Hey, yeah. We did try a stock p30 ecu (forgot to mention), error still showed, so im going to run a fresh wire direct to the ecu to see if it clears it up.
a1320honda
May 17, 2014 12:00 AM
monster d
Jun 12, 2013 10:20 PM
SPOOLINmatt
Mar 17, 2010 05:43 PM
vtec93accord
Apr 8, 2008 05:19 PM
ludelvr
Mar 13, 2005 05:57 PM
