trouble with dsm blue-tops
Old Feb 6, 2013 | 06:38 AM
ChokolAwt's Avatar
Default trouble with dsm blue-tops
I cant seem to get the idle right. these things are finicky as hell!
engine is a mini me (a6/y8) with a couple bolt-ons. I've managed to smooth out the afr's to ~14.5 at idle, but once the car is warmed up it doesn't like to idle. Like, coming to a stop and the revs fall, they just fall too far haha.
How much timing can I add in the idle portion? im at 19* right now. does someone know of a website that outlines the correct procedure for tuning the idle?
Old Feb 6, 2013 | 02:41 PM
GhostAccord's Avatar
Default Re: trouble with dsm blue-tops
What software are you using?
Did you set up your injector offset and the injector battery offsets before you started making any adjustments to the main fuel tables?
Are you running a resistor box or peak and hold injector drivers?
Why did you choose 450cc injectors for this build? Seems like they might be a bit much!
Old Feb 8, 2013 | 08:51 PM
ChokolAwt's Avatar
lol sorry, it has a greddy kit on it. td04h 6psi. im using neptune. i've done the injector offset but unsure about the battery offset. im using a resistor box.
Old Feb 8, 2013 | 09:04 PM
Well running 6psi is a bit more than "a couple of bolt-ons"... Not that it really matters for your idle.
Idle timing is usually lower not higher... you are not under boost and or any sort of engine load. 16-17 is what I usually aim for in those areas/cells....
Old Feb 16, 2013 | 10:18 AM
VegasInvasion's Avatar
I'm Huge In Japan
Stop tuning your idle when it hasn't warmed up yet. If it's too rich when it's cold, lower the temp compensation for that range. Make sure your target AFR is the same in all achievable cells in the idle range. If you're choking on decel, add more IACV duty cycle, or back the idle screw out a little. any repair manual explains base timing calibration.
Old Feb 18, 2013 | 11:38 AM
ChokolAwt's Avatar
awesome info. thank you! i've since taken the turbo off and am sourcing some stock injectors.
Infamous war
Engine Management and Tuning
Aug 8, 2012 10:03 AM
bnmm
Aug 31, 2011 10:41 AM
oneludesol
15
Jan 12, 2010 11:13 AM
aalb1
12
Oct 4, 2008 05:47 PM
a1320honda
Sep 6, 2007 12:55 PM
