JDM ITR transmission clutch housing
Guys, needs something cleared up. In the following pic is a JDM S80 ITR 4.7 FD transmission. It has an enclosed bearings with the differential. Do these come with a shim under the differential in the clutch housing side? Because we just took apart the transmission and we are not sure whether we misplaced this part.
Re: JDM ITR transmission clutch housing
Actually we took this apart a transmission to install Mfactory 3rd - 1.652, 4th - 1.296, 5th - 1.00 close ratio gearsets and new oem 3-4 synchros, springs, hub and sleeve. So we fixed everything thing up, all gears aligned and turned up freely, shift forks lined up etc. Finally got the c-clip on the bearing groove and tightened the housing. But after tightening the housing bolts the input shaft wasn't moving freely, it was turning with resistance and after a half turn, it gets harder and then loosens a bit. Changed into different gears and checked, it was still the same. But if the bolts were loosened it turns somewhat freely. What could be causing this?
kay_animation
05-16-2005 01:57 PM
