S4C Counter Shaft with LS Ring Gear?
I'm 99% sure I have to swap the entire final drive ring gear/countershaft, but I just wanted to double check. I'm using an S4C trans with Mfactory diff. I need to stretch the gearing out just a touch and have a good LS trans laying around. Was going to rob the ring gear and countershaft from the LS. I see the part numbers are in fact different between the two, just wanted to make sure that I'm not able to swap my ring gear in and leave the countershaft untouched.
dcraige
04-02-2010 06:32 PM
