Hasport axle issues
Hasport axle issues
Hey guys,
alright so after going through 3 sets of cheap axles i decided to buy a set of hasports.
been daily driving on them for about a month now and they just started clicking.
its a very quiet click and only happens on hard turns.
Is this click the same click thats associated with worn cv joints or is this normal with performance axles?
should i contact hasport?
thanks in advance
thanks in advance
Re: Hasport axle issues
I agree with Aquafina... if this is a street driven car with normal front end geometry and is lowered 1.5-2 inches... it should be fine... unless the front end has been really smashed or something.
H-T Premium Sponsor
I want to rule out any other possibilities before replacing the axles, any ideas on what may cause premature wear on the cv joints?
H-T Premium Sponsor
its an LS, so i swapped in the b18c5 with the gsr box using the stock ls mounts, had no issues with the swap. Engine and gearbox are completely stock. They drive perfectly fine, all i noticed was the clicking so far on the outer joints. no vibrations or anything like that
i highly doubt there is premature axle wear going on as the axles only make noise when turning hard
you say you went thru 3 sets of axles before? what happened with those axles?
Yep manual. my last 3 pairs of axles met a similar fate, they all started clicking after about a month or so of daily driving. I was told by several mechanics and others on here that i just needed to buy a pair of good quality axles. But now im suspecting that theres something else thats causing them to break, rather than the axles themselves being at fault. I doubt its my suspension geometry so im trying to figure out what's making my car an axle killer.
